PINNED - R-Net for dummies
Re: PINNED - R-Net for dummies
Postby snaker » 08 Apr 2026, 10:42
@Burgerman: Do you know what terminal sizes match the power and motor pins on r-net PM?
Postby Burgerman » 08 Apr 2026, 11:04
I think they are 9.5. and EITHER 4.8 or 6.3.
Dont shoot me when I am wrong! I just dig into the draw and see what fits!
https://www.arc-components.com/0-005-24 ... -3157.html
These are for bigger cables...
The small ones (brakes) may be 4.5 or 6.3...
Postby snaker » Yesterday, 03:58
I am testing the open r-net project. I cannot make the PC see the r-net PM through an usb-to-can adapter.
I have some questions:
When using an oem dongle, how do you connect it to the PM?
Do you directly connect it to the 4-pin hole on the PM?
Or do you indirectly connect it to the 3-pin hole on the joystick?
In the case if you directly connect it to the 4-pin hole on the PM, do you need to connect the PM to the joystick first to trigger the programming mode?
Postby Burgerman » Yesterday, 07:13
I put it BETWEEN the pod and the joystick, but it works on any spare bus cable you may have.
Users browsing this forum: saker98 and 493 guests
