Postby Burgerman » 29 May 2012, 11:36
Thanks for the update.
Any good links to buy this cable? I will make a couple up.
Already have some 3 pin charge XLR/Neutrik plugs in the draw.
ADDED
I changed over to using an FTDI cable TTL-232R-3V3-WE as the basis for ALL my programming leads
@ B.M. ....You might consider altering the start of the pinned thread and removing any references to the Prolific / KPG cables and their variants....replacing any references and pics with the current FTDI Lead.
Re: PGDT interface update
Postby Burgerman » 29 May 2012, 14:05
And they do paypal! So its easy... Ordered. Thanks.
Postby woodygb » 29 May 2012, 14:39
They normally arrive next day / signed for.
Postby Burgerman » 30 May 2012, 11:20
It did. Will make a lead up soon, post a really simple how to page, mention your name, and then its easy for all. Unless you want to keep making these for others? In which case I will link to this thread.
Once people see that its just 2 wires, and easy to get lead / connector then they will make it themselves I expect. Will work for everything P and G inc VSI, Pilot Plus, VR2, and some scooter controllers. It will not do R-net.
Postby woodygb » 30 May 2012, 12:44
Thanks for asking.
I'm not in this to make MONEY .... I am a non-loss rather than a "non profit" person. :)
Feel free to post any info on your main site ...
I've presently got 2 leads ordered by forum members.. and will if asked continue to assemble them.
EDIT:- I did get a price for 100 off ...assembled with compatible plug ... of under $10 U.S.
Postby woodygb » 30 May 2012, 12:50
Seems a more difficult nut to crack ... I would need the pgdt lead/dongle and a controller to get a starting point.
Postby Burgerman » 16 Jun 2012, 16:11
ADDED
CONFIRMED GOOD:
1. COMPATIBILITY MODE for XP SP3. (been using it since the start - not sure if its needed)
2. THIS cable: http://www.radioarena.co.uk/index.php?_ ... ductId=628 Connect as per woodies picture. Image
3. The driver on the disk it comes with... Which has a bunch of drivers on it. Just run the disk. It installs 3.2.0.0 driver. Changed this to COM 8 as the others do not work on 2 PCs...
4. Choose com 8 in the PG Drives program. woohoo...
Not sure how much of this was my bad connecting Neutrik plug. They are sh*t...
But the above works flawlessely.
Postby woodygb » 16 Jun 2012, 17:24
ADDED
Postby woodygb » 16 Jun 2012, 21:23
Prolific PL2303 ver 3.2.0.0 driver zip
http://sdrv.ms/LcQ1B7
ADDED
Postby Burgerman » 16 Jun 2012, 21:24
Comes with disk.
Postby woodygb » 16 Jun 2012, 21:30
Indeed ..but some people MAY have made a lead and that zipped driver could possibly help.
http://groups.yahoo.com/group/TG-UV2/message/895
Postby vr2hacker » 18 Jun 2012, 20:56
Just new to this topic... has anyone tried the FTDI USB cables? They work on Windows, Linux and Mac OS.
The advantage to them is that the drivers work perfectly on many platforms.
Install FTDI driver, plug in cable. About $20.
Cable (very widely available from other sellers, search for " FTDI TTL-232R-5V")
http://www.digikey.ca/product-detail/en ... ND/2003493
Drivers
http://www.ftdichip.com/FTDrivers.htm
They sell the chips, which means many people have made adapter boards for USB-TTL levels, such as this one:
http://shop.moderndevice.com/products/usb-bub
Millions of these are in service, notable in the Arduino robotics/hobbyist electronics platform.
D
vr2hacker
Postby woodygb » 18 Jun 2012, 21:08
The problem is in finding a lead that communicates with the PGDT controller and will thus allow programming of it.
1-wire communication ....
Postby vr2hacker » 18 Jun 2012, 22:27
the FTDI cables should work the same, since they provide the same signals as the PL2303: RX and TX at 5V TTL levels.
The Kenwood isn't really one-wire, since the technique is to tie together the RX and TX lines, but I know what you mean.
I'm hacking a VR2 for a robot controller and trying to figure out what they did in hardware to complicate things!
D
vr2hacker
Postby woodygb » 18 Jun 2012, 22:50
Bypass the VR2 control interface and hack in at the h bridge.
http://hh.diva-portal.org/smash/get/div ... FULLTEXT01 page 33 ish
What type of robot?
Postby vr2hacker » 19 Jun 2012, 04:45
thanks for the tip! It's not the same motor drive though, but I see what you mean about bypassing the PG proprietary protocols and going straight to the heart.
I just spent about four hours hacking the VR2 and it works when you send analog PWM voltages from an Arduino to the joystick connector, but it really has an unreliable feeling to it.
Have decided to go with a Roboteq controller instead! it will work and is much more reliable, and you can get replacements and information without having to screw around with PG's supply chain.
D
vr2hacker
Postby ex-Gooserider » 19 Jun 2012, 08:00
vr2hacker wrote:Just new to this topic... has anyone tried the FTDI USB cables? They work on Windows, Linux and Mac OS.
I don't know about doing the straight from USB - controller setup, but the FTDI USB -Serial adapter, and the standard P&G serial cable has been reported by others to work on at least some Microsoft platforms, and I just got it working under VMware on a Mac... So I wouldn't be terribly surprised if that was a workable approach.
I don't know how it would like having it's TX & RX pins tied together though, I could see how that might confuse it. There might be a need to have some kind of protection on them. However the technical reference info is probably going to be easy to find, so that should be an easily answered question...
Postby Burgerman » 19 Jun 2012, 09:32
Thats why we have to reprogram every powerchair to get rid of this crap... So it steers correctly.
Postby woodygb » 19 Jun 2012, 10:40
You do need a few extra components to divert the signals ... the Kenwood cable appears to have a version of the middle schematic tacked onto it's RX /TX .
3 onewire.GIF (34.54 KiB) Viewed 94891 times
Postby malamar » 21 Jun 2012, 19:03
Pardon...? :? :mrgreen:
malamar
Postby Burgerman » 21 Jun 2012, 22:41
You dont need to understand that!
Postby malamar » 22 Jun 2012, 12:23
A true relief! :?
malamar
Postby butchec » 26 Jun 2012, 09:29
I am new to the forum and wanted to check which cable was best.
From reading this list the Kenwood KPG-4 seems to be the best and most reliable. But reading some other lists a Icom OPC-592 cable was mentioned.
Has anyone tested the Icom cable? If so which offers the most reliable connection.
Thanks. Chris
butchec
Postby woodygb » 26 Jun 2012, 13:07
The KPG 4 is recommended for ALL Windows O.S.
BUT so far ONLY that specific type as supplied by RadioArena.
Postby woodygb » 26 Jun 2012, 14:31
The ICOM works for ME on XP .... I'll happily send you the ICOM to try.
Postby Burgerman » 26 Jun 2012, 17:45
It doesent work in Win 7 though.
Postby Ashley G » 26 Jun 2012, 18:01
Burgerman wrote:It doesent work in Win 7 though.
I'm just wondering .... in Win 7, we can set programmes individually to run in XP SP2 compatibility mode (for example), but how would you tell a driver what mode to run in ?
I'm assuming that it's the driver which is causing you guys all the headaches. I confess to getting a but muddled now and then ....
Regards
Ashley
Ashley G
Postby Burgerman » 26 Jun 2012, 19:48
No, that makes no difference. I tested all of woodies leads, and the only one that seems to work is the 4 wire one. And it connects easily, and solidly. It may be a driver issue, but I tried that same driver (included with the lead) on all of them. Still only the 4 wire lead worked.
Postby butchec » 26 Jun 2012, 21:25
Thanks for the advise on the cables. Since I am running win7 on all computers I am going to order the KPG4 cable.
Cheers. Chris
butchec
Postby butchec » 30 Jun 2012, 13:06
Cable just arrived...
Let the testing begin
butchec
Users browsing this forum: Bing [Bot], Burgerman, jefferso, rover220 and 379 guests
