lordk wrote:Yes, output 1 , output2 and center are all shortened. Iam missing something here.
woodygb wrote:When you replace the joystick with some other interface device you must then emulate ALL the original joystick voltages.
woodygb wrote:rune wrote:I'm not happy with the programming cable thing....
I bought the radioarena cable but i'm having even less sucess with this one than my previous cable; I think it's faulty.
In windows, on two separate machines, in win2k and XP the driver will not start correctly (error 10). I've tried different driver versions, etc but to no avail.
I have four or five other USB cables with use the PL2303 driver and on each one of these, they show up and work with no problem.
I'm going to have to contact radioarena and see if I can sort this out. The only trouble is, i've already chopped the modular plug on the end and soldered on an XLR
I'm confused as to why you ignored this pic ...or did you not see it?
And how you came up with your own colour connection version.The one I had worked out to white common, black and red TX and RX.
of the case type shown in the above picture.I have yet to find any radio programming cable
( KPG Baofeng etc ) that will not work with the addition of the diode.
PowerHungry wrote:Hi woody
I just got a qtronix/p&g 100 amp module off ebay and need the cable you made and I was wondering if you would sell me a cable please as I am rubbish with diy electrical stuff?
PH
woodygb wrote:PowerHungry wrote:Hi woody
PH
Not sure how I missed your request ... I can if required supply a USB based cable.
woodygb wrote:There is a link for uploaded software here and it will program the Pilot+...
viewtopic.php?f=2&t=3461
woodygb wrote:£20 plus postage ...I'll need to order in another couple of leads to modify.
woodygb wrote:Ready ..P.M. me your details.
woodygb wrote:There appears to be NO SET colour for the wires ...the wire colours seem to vary depending on the whim of the Chinese supplier of the cable.
Popping the case is the only way to be absolutely sure.
Here's an updated pic ...AND ... I have yet to find any radio programming cable ( KPG Baofeng etc ) that will not work with the addition of the diode.
Users browsing this forum: Williamclark77 and 420 guests
