Burgerman wrote:I will do it outside. It wont start without accurate neutrals. Which if I remember correctly were nowhere near the real 2.5v real midpoint for some reason.
rustyjames wrote:Woody, if you decide to sell any, I'm still interested and would be happy to send you some money up front for one.
woodygb wrote:rustyjames wrote:Woody, if you decide to sell any, I'm still interested and would be happy to send you some money up front for one.
Let us see how well the testing goes ... I really want this interface to be Super Easy ...as close to plug and play as possible and SAFE.
THEN ..I'll be happy to provide some.
B.M. has the experience etc to Beta test ... hopefully no problems will crop up.
Well lets hope it isn't to far away as the default neutral is SET @ 2.5v
Nope ...my program outputs 2.5v at the R/C Neutral point set during Calibration.
Burgerman wrote:Also the output on the Omni is 12v. Is there 5v available now on your board to take the RX power from? (and with 3 added sats?)
6.1.1 Joystick calibration
Each time a new joystick type input device is connected to the Omni+ Module, the
system should be calibrated. To enter joystick calibration mode, switch the Omni+
Module on while depressing the Select button. After the normal power-up message,
the joystick calibration screen will be entered. At this point simply follow the instructions
on the screen and depress the Select button to accept the instruction.
Example: The first instruction is to center the joystick. The screen will appear as below.
Ensure the joystick is in the center position then depress the Select button. The next
instruction will appear as shown on the screen below.
Center Joystick
ok
Push Joystick F'ward
ok
Deflect the joystick to the full forward position, hold it there and depress the Select
button. The next instruction will appear etc.
Burgerman wrote:. It wont start without accurate neutrals. Which if I remember correctly were nowhere near the real 2.5v real midpoint for some reason.
For optimum performance, The Omni+ module should be calibrated for individual
joysticks. The voltage swing of 1.2V is a nominal value, actual values of between 1.1V
and 1.3V will be accepted by a calibration sequence.
If the voltage swing with respect to Vpin3 exceeds 3.0V, then the Omni+ Module will
assume a fault condition.
Users browsing this forum: Burgerman and 375 guests
