Burgerman wrote:Where am I getting the 5v from and the ground for the RX because it appears not to do anything if I connect the ground and the 5v wires.
Then it lights up solidly when I connect the servo signal wires. But should flash as its got a bind plug in... The ground appears not to be ground...?
Burgerman wrote:RC and calibration etc works. But still get the Omni joystick error. So will now play about with trims till it starts up...
Burgerman wrote:What resistors should I order? Electronics not really my thing!
I thought a 1k and a 470 20 turn for adjustment? And I am not sure my eyes are good enough for this!
I feel sure this is all it requires.
Joystick input is not related to the + 12v or 0v but only to the reference voltage that the JOYSTICK supplies. Now while this is about 6v I think, (12v joystick) I don't see that it will be any different at 2.5v? I hope.
... my electronics isn't much better than yours B.M. ... TRY IT .2X 1K resistors? To red wire and prey!
Users browsing this forum: No registered users and 442 guests
