Burgerman wrote:Those appear quality and genuine.
expresso the slime doesent expand. What you saw was air still in the tube. The sealer maybe blocked the valve. You must remove the valve core.
I have a Meyra Vertical Nemo chair. But my friend and I are making our own chair based on the R-NET system.
in the end, and faced with the situation that we can not configure the limit switches on a new stroller. And didn’t anyone try to upgrade the programmer for the OEM version or replace the key file? And the question is where, in principle, can I buy an OEM key?
Armitage3000 wrote:Good afternoon!
OEM software worked and the setup menu for actuators and limit switches became available when the configuration was saved. But unfortunately, the chair could not be reprogrammed due to the USB key of the programmer version of Dealer. But do not you know how to carry out keyless reprogramming or perform key replacement for the OEM version?
snaker wrote:I am using these Kenda 3.00-4 and 3.00-8, they are really good. Although I am not sure if they are genuine.
https://detail.tmall.com/item.htm?id=58 ... 0422221459
https://item.taobao.com/item.htm?id=19995835723
Users browsing this forum: Williamclark77 and 406 guests
