mat that when seated on a roo the pressure will be between .5 and 1psi. So: I have hot solder, sharp shrapnel (swarf) from drills and lathe and today was cutting a bit of steel on my knee with a grinder. You can imagine what happens with an air cushion... With a super thin easily melted cover
The closing pressure of arterial capillaries is 32 mmHg or 0.62 psi (1 psi = 51.71 mmHg) which means any pressure higher than this exerted on the capillaries will cause an impediment in the flow. This gives a target for reducing the pressure to as close to 32 mmHg as possible.
I have found an easy way to set the ROHO Quad. When off of the cushion over inflate with the chamber valve open so all 4 corners are over full.
Leave the inflate valve open and then just let the cushion deflate for about a minute, long enough for the cushion to settle and equalize to room air pressure. Close the inflate valve and the chamber valve. This works very well for me. This method gives me a little bit more than a finger clearance.
) the cushion gets soaked... However the cushion and cover are all machine washable, and machine dryable (the machines have to be large and non-agitator style to handle the cushion) but I find that it works if I just hose it down w/ plenty of soap and water in the shower. It then takes a couple days to air dry, so having enough to 'rotate' helps. They also seem to lose some of their support after a year or two (or at least that is what the insurance will cover....)Burgerman wrote:Now I want a pressure mapping setup. I tested one and played with it many years ago at the spinal injuries unit. Its a tool. Its not everything. But its useful. I did not realise then, quite how critical these pressures are, and how important the peak pressure on the ishial bone area was. It is ESSENTIAL to get this cusion pressure below 27mm of mercury. This was before I found out the cost!!! These things are REDICULOUSLY expensive. You can buy a new car cheaper.
So any idea of a mapping setup that is AFFORDABLE?
Have a careful read here download/file.php?id=15025
Is it a potential DIY project?
Users browsing this forum: acid_coke, emilevirus, JazzyBand and 426 guests
