R-Net PC Programmer OEM
Re: R-Net PC Programmer OEM
Postby Burgerman » 17 Aug 2021, 19:29
Thanks for the upload.
So it appears that the power module is programmed to only work with the permobil module for stability plugged in and working. As all the normal speed settings are set to 100 or 50. And instead you program the chair on the permobil stability nonsense thingy. If thats not working you will need to disconnect it and convert it to "normal" programming. I know that works as I have copied my sunrise profiles to 2 bought 120A Permobil power modules and they are now "normal"...
So your best bet is to use either of these two profiles. Or junk the permobil parts and convert it to a normal power module. So no permobil ESP settings.
But I cant say how good or bad that will work as turn acceleration, turn deceleration, minimum turn acceleration, and minimum turn deceleration all see way way too low to me. I wouldnt be able to hit a doorway that way. On both profles. But at least you know they work.
Postby Burgerman » 18 Aug 2021, 23:03
FelipeOliveira i think a bit of a translation ptoblem here.
Postby FelipeOliveira » 19 Aug 2021, 02:28
Burgerman wrote:FelipeOliveira i think a bit of a translation ptoblem here.
translated:
I agree ! I write in Portuguese (Brazil) and translate, and send!
If I post in Portuguese directly, the translation would be better?
Portuguese:
Concordo ! Escrevo em Portugues (Brasil) e traduzo , e envio !
Será q se eu postar em portugues direto a tradução ai ficaria melhor ?
FelipeOliveira
Postby Burgerman » 19 Aug 2021, 02:41
Unfortunately no. Because I have to run it through the same translation program!
Postby FelipeOliveira » 19 Aug 2021, 04:08
Burgerman wrote:Unfortunately no. Because I have to run it through the same translation program!
è that You have no idea or appear when I put it to translate what you write .. kkkkk
FelipeOliveira
Postby Burgerman » 19 Aug 2021, 09:13
?? Quite! czy :problem:
Postby FelipeOliveira » 20 Aug 2021, 06:23
Burgerman wrote:?? Quite! czy :problem:
good night burgerman . after much insistence, I managed to identify . exactly the “ESP”. replaces and it was possible to drive! now I just need to understand how to adjust and adjust the actuators and sensors, if possible disable the limit sensors and "ESP"
FelipeOliveira
Postby Burgerman » 20 Aug 2021, 08:10
The ESP on a permobil is actually their own stability module used instead of the r-net parts.
Postby FelipeOliveira » 20 Aug 2021, 19:57
Burgerman wrote:The ESP on a permobil is actually their own stability module used instead of the r-net parts.
Is it possible to disable it?
FelipeOliveira
Postby Burgerman » 20 Aug 2021, 20:00
On a permobil its all part of their non r-net system/firmware and seating stuff. I dont know what it will do if you unplug the whole thing. Probably lose that part of the menu, and revert to normal speed settings that make sense.
Dont know as I dont have a permobil (by choice for exactly these reasons). Try it.
Postby garethmitchelson » 27 Aug 2021, 13:20
Could anyone please give a link to sunrise r-net OEM pc programmer software .Thank you.
garethmitchelson
Postby FelipeOliveira » 27 Aug 2021, 13:50
garethmitchelson wrote:Could anyone please give a link to sunrise r-net OEM pc programmer software .Thank you.
https://powersoccershop.com/pcprogrammer.aspx
bought mine, last month, OEM (Type B)
FelipeOliveira
Postby kashmiri » 04 Sep 2021, 23:19
I don't have the OEM version, but a dealer version can be downloaded from https://amylior.com/software/
kashmiri
Postby Burgerman » 04 Sep 2021, 23:27
But we do have it here!
Also the OEM can be downloaded from the Dietz wheelchair website.
Postby kashmiri » 04 Sep 2021, 23:42
Burgerman wrote:But we do have it here!
Cheers man! Now only need the dongle, lol.
kashmiri
Postby Burgerman » 04 Sep 2021, 23:52
No you dont!
PM me...
Postby rapkar1 » 08 Dec 2021, 11:06
Looking for a DONGLE R-Net DEALER.
Where to buy at a good price?
Anyone have for sale?
rapkar1
Postby Burgerman » 08 Dec 2021, 13:16
Why dealer? Those are available from any wheelchair dealer or direct from pgdt. Its the OEM dongle that is hard to get.
Postby rapkar1 » 08 Dec 2021, 22:28
dealer because it is cheaper, and it is enough to upload the parameters saved in the oem version, right?
Getting it for a reasonable price is probably not as easy as you write. I found the cheapest one for 490 Eur. Does it really cost that much?
Maybe someone has a used for sale?
rapkar1
Postby Burgerman » 08 Dec 2021, 23:11
Usually it s cheaper.
Sunrise medical retail price is:
Article no.: 108532
Description: R-Net PC programmer (dealer version), inclusive USB cable
Remark: Supplied with software, dongle and cable
List price: £ 254.93
Postby rapkar1 » 08 Dec 2021, 23:22
thanks, sent the inquiry
rapkar1
Postby kaban » 20 Jan 2023, 20:16
Could anyone please send me a link to sunrise r-net OEM pc programmer software .Thank you
kaban
Postby Burgerman » 20 Jan 2023, 21:41
PM me...
Postby A_dam_ » 07 Feb 2023, 00:41
Also got my hands on an OEM dongle. What's the latest version out in the wild? 6.4.1?
A_dam_
Postby Burgerman » 07 Feb 2023, 00:46
I think so. Not checked lately.
Postby slomobile » 10 Feb 2023, 19:24
I am not convinced that a dealer dongle can actually read ALL of the OEM settings actually programmed into a PM until I see a file made with OEM dongle and dealer dongle side by side using OEM software (which changes to dealer mode whenever a dealer dongle is plugged in). Individual settings can be designated read, read/write, or write by the OEM.
So I've been trying to get an OEM programmer to test first hand.
Simpelmed in the Netherlands pulled a bait and switch sending an open box dealer programmer instead of the type B programmer listed non the invoice. Still unresolved.
BM said the power soccer shop was shipping overpriced but genuine OEM B programmers, so I ordered one. In the order comments I specifically asked for OEM type B. I was told it was out of stock and they didn't know when it would ship. It arrived today, nicely boxed, sealed. It has no markings anywhere on the box exterior saying OEM, or Dealer, or A or B. Invoice just says PC Programmer Part No. 5063. a label on interior box says D50612.26 and 230119265
Opened it to find another type A dealer dongle inside. I've spent over $1000 trying to get this thing BM says is so simple to get. I call bullshit.
Does anyone with a genuine type B want to trade for 2 type A?
slomobile
Postby woodygb » 10 Feb 2023, 19:31
Not sure if Salam still has it for sale ...
https://www.wheelchairdriver.com/board/ ... =1&t=11695
Postby slomobile » 10 Feb 2023, 20:14
Thanks! PM sent. I forget that section of the website exists sometimes.
slomobile
Postby FelipeOliveira » 10 Feb 2023, 21:15
Good afternoon
I got an OEM TYPE B, exactly at powersoccershop. Where the BM indicated. Soon after, the intem became unavailable. I believe it has to do with my purchase. Because the PGDT. It was difficult to release my login. After all, I'm in Brazil and theoretically according to their policy, I would buy in Brazil. But for the local dealer. It made my acquisition difficult. For personal problems! I may be wrong but that's the impression I had in the face of the facts!
FelipeOliveira
Postby Burgerman » 10 Feb 2023, 23:01
Trust me it can. I have both. I checked many times. You send me a dealer file, and I can read and change every OEM level setting. And I can email it back to you and your dealer dongle will write that complete witth everything I changed to your chair. And no you wont see many of the changes. At least on any normal R-Net system. PM me and I will tell you how to do this with your dongle.
Not on a permobil however. With either dealer or oem dongle.
Users browsing this forum: Bing [Bot], emilevirus, jefferso, slomobile and 395 guests
