Controllers for lightweight chairs
Postby emilevirus » 24 Dec 2024, 17:30
3 years ago I bought a lightweight power wheelchair from china. It uses 2x 5Ah lion batteries in parallel. Only weighs 17kg. It's awesome to travel. But the controller is awful. It has a very slow response time. I have R-Net controllers laying around but I guess it's overkill for two small motors and it'd make the chair heavier. I'd like a programmable controller ideally. What'd you recommend?
emilevirus
Re: Controllers for lightweight chairs
Postby Burgerman » 24 Dec 2024, 17:37
Is it a chinese brushless? If so normal mobility systems wont work.
Postby emilevirus » 24 Dec 2024, 18:35
It said brushless but nahh it's brushed, pretty sure. Motor wires is just a XT30 connection.
emilevirus
Postby Burgerman » 24 Dec 2024, 18:38
Only 2 motor wires?
If so then yes you can use a mobiity cotroller. You can use VSI or something that is an all built into the joystick. Will need OEM programming to set correct brake voltage, motor compensation etc.
Postby emilevirus » 24 Dec 2024, 23:52
Also, I now use my iCharger to charge the batteries. Stock charger is 1A and I charge at 10A. Do you think it's fine? Usually RC batteries can be charged at 1C just fine but these idk, I cant see the ratings. I can feel the BMS getting hot tho. It gives a nice boost. 10min charge and I'm good for a few miles.
emilevirus
Postby Burgerman » 25 Dec 2024, 00:07
Well that depends what cells are in that battery. Probably too high. Most 18650 cells such as laptop batteries CAN be charged at 1C but live a lot longer is charged at 0.2C as the spec sheets normally tell you. They also need to be stored less than full. And balanced accurately. And if charged at say 4.1V per cell will last at least 3x longer.
Postby emilevirus » 25 Dec 2024, 01:46
Yeah, it'll already be a huge upgrade being able to store them. And the iCharger already defaults at 4.1V for lion. BMS may not balance them until they're at 4.2v tho, I think they're 21700 as they're 5200mah unless it's 7s2p
emilevirus
Postby shirley_hkg » 25 Dec 2024, 02:34
That clearly means two 18650 cells @2600mAh.
I'd charge at 0.25C for safety sake.
That will be a problem if you charge it to 4.1V, while BMS starts balance ≥ 4.2v
Postby Burgerman » 25 Dec 2024, 17:37
If that is the case. Most balance all the time, like my laptop or rc transmitter.
And still no problem if occasionally charged full.
Postby hank » 21 Jan 2025, 15:36
Hi
Could anyone tell me if a Quickie Q50R lightweight wheelchair uses brushed motors
What i want to do is fit R net joystick plus PM to make it steer properly
looking for a lightweight indoor chair to replace my manual one as getting weaker now
Postby emilevirus » 21 Jan 2025, 15:43
PMDC is brushed. 2 wire is brushed.
emilevirus
Postby emilevirus » 21 Jan 2025, 15:46
If you fit R-Net, you'll need a switch because it always consumes a bit of power and your batteries will be flat if you let it sit a while.
emilevirus
Postby martin007 » 21 Jan 2025, 17:39
emilevirus wrote:If you fit R-Net, you'll need a switch because it always consumes a bit of power and your batteries will be flat if you let it sit a while.
I didn't know that detail.
What switch do you have Burgerman?
Postby martin007 » 21 Jan 2025, 17:44
Burgerman wrote:Is it a chinese brushless? If so normal mobility systems wont work.
What features do those controllers have to be so different? :computer
Postby emilevirus » 21 Jan 2025, 17:54
Brushless is very different. It has 3 wire and always uses the same voltage even if it's going slow. Brushed is just voltage variation that controls the speed, brushless is pulse.
emilevirus
Postby Burgerman » 21 Jan 2025, 18:01
The chinese brushless controllers are a bit like the RC steering in a toy for a child. A few lines of code, and they dont steer well. They are also almost impossible to access a programmer anyway.
The BRUSHED controllers made by PGDT for e.g, have decades of fancy coding, are very controllable, and can be programmed to steer well and you can get programmers.
You get what you pay for here.
As for draing power when turned off, ALL controls systems that I ever saw have a very small drain on the bateries when turned off. In the order of 4 to 12 mA.
You can fit a switch, trip the breaker, pull out the battery, add a "loop" on an anderson connector, or whatever to prevent this. But batteries also have a similar but smaller drain internally too. So even if you disconnect a battery with a plug, fuse, remove a cable etc then it will take LONGER but will still have a small continual discharge.
A lead battery that isnt 100+% fully charged will deteriorate faster than if it is kept full.
A lithium battery is the opposite. If its lithium, use it and if you need to store it do so at around 30 to 80% charged. They live longest when at around 50%. So storing above 50 and below 80 will mean that even if stored many months it will be fine!
With one possible issue. BALANCE! Each cell is different. Stored for a long time will unalance the pack. So charge fully (only way to balance) every 3 to 6 months. Then discharge back to around 70%.
All my lead batteries are stored on a LOW float. Or charged every 2 weeks at a NORMAL float charge voltage overnight.
All my lithium batteries inc laptops, power tools etc are stored at around 80%.
Postby emilevirus » 21 Jan 2025, 18:16
Well, 12 mA on a 10Ah battery is a lot. That's 2Ah a week! On the Chinese controller I currently have, I must turn it off. Otherwise 2 weeks later it's flat. I don't use that chair often either so...
emilevirus
Postby Burgerman » 21 Jan 2025, 18:56
Yes but those are lithium. Lithium doesent like being full anyway.
And if it does manage to discharge it completely over time those cells have a BMS that switches off power. Although thats not a great idea really at least it wont kill that battery completely! But the battery is removable on those. So just pull it out. However. The built in BMS in the battery ALSO draws a very small current and often on just 2 cells! Which is why the manual likely says charge before storing it or similar.
Postby emilevirus » 21 Jan 2025, 20:48
Burgerman wrote:Yes but those are lithium. Lithium doesent like being full anyway.
Yeah but in my case, a lightweight chair I use only when I need it like once a month. If I leave the controller on, everytime I want to use it, it's dead so a switch is really needed in this case.
emilevirus
Postby Burgerman » 21 Jan 2025, 21:09
Can you just unclip the battery and lift it partly out?
Postby hank » 21 Jan 2025, 22:30
THANKS :thumbup:
Postby hank » 21 Jan 2025, 22:34
THANKS :thumbup:
ANY OTHER CHAIRS TO SWAP TO R NET WITH BRUSHED MOTORS TO USE BETTER THAN THE QUICKIE Q50 R
Postby Burgerman » 21 Jan 2025, 23:18
I am baffled by that.
What are you asking or saying?
Postby JohnnyUK » 21 Jan 2025, 23:33
hank wrote:Hi
I bought a new Q50R Carbon last year with the cheap Chinese motors and nVR2 controller, it's pretty uncontrollable but as usual we can't access the program. The motors are horrible gritty noisy 250W Brushless things.
I'd be interested to hear what it steers like with R-Net good luck to you. Can't use mine anymore so it's going on eBay
JohnnyUK
Postby biscuit » 22 Jan 2025, 00:12
access the program.
WoodyGB made me a connector that worked on the nVSI of my Vienna.
biscuit
Postby biscuit » 22 Jan 2025, 00:14
biscuit wrote: can't access the program.
I thought the Q50R had a VSI?
biscuit
Postby Burgerman » 22 Jan 2025, 00:25
If it has then its programable. Chinesium ones mostly dont, same basic folding chair as sunrise one with a chinesium controller.
I think you wont have room for an r-net controller power module even if your one is brushed.
Postby emilevirus » 22 Jan 2025, 01:23
Just ordered the connectors for motor & battery along with a led joystick. Will let you know how it goes. Mine doesn't have electromagnetic brakes so I'll need to disable that.
emilevirus
Postby Burgerman » 22 Jan 2025, 01:32
Never tried it but disable these top two...
Postby emilevirus » 22 Jan 2025, 01:39
Current limit can't be lower than 50A but if I set power limit to 50%, that should limit it to 25A right?
emilevirus
Users browsing this forum: No registered users and 308 guests
