EBay search name rearwheel 3 holes 3.00-8
Re: EBay search name rearwheel 3 holes 3.00-8
Postby shirley_hkg » 27 Jan 2025, 02:14
Can somebody tell me the diameter of the drive axle of Permobil F5/F3 please ? cheers
Postby wheelchairer » 27 Jan 2025, 12:38
When I try to move forwards it goes backwards, when I try to move right it goes left, when I put the back rest forward moves forward, when I move the joystick backwards the bat rest goes backwards. Obviously I will be able to check whether it goes up full speed, 6 mph or not.
C4/5 tetra
wheelchairer
Postby Burgerman » 27 Jan 2025, 13:22
Right...
Let me fix that!
I reversed BOTH motors,
I think it will now be OK. Forwards will go forwards.
But if it still turns opposite way, LET ME KNOW. I think that will fix the turn too...
We deal with seating next.
12V BRAKE 6.2MPH 45MOHMS COMPENSATION ADDED PROFILE reversed motors.R-net
(4.33 KiB) Downloaded 59 times
Postby wheelchairer » 27 Jan 2025, 13:25
When I try to move forwards it goes backwards, when I try to move right it goes left, when I put the back rest forward moves forward, when I move the joystick backwards the back rest goes backwards. Obviously I will be not able to check whether it goes up full speed, 6 mph or not.
C4/5 tetra
wheelchairer
Postby Burgerman » 27 Jan 2025, 13:40
Did you just try the new settings file above yet???
Postby wheelchairer » 27 Jan 2025, 13:49
Burgerman wrote:Did you just try the new settings file above yet???
Yes with that file untouched by my incompetent hands it does the following :thumbup:
C4/5 tetra
wheelchairer
Postby wheelchairer » 27 Jan 2025, 14:04
Burgerman wrote:Right...
Let me fix that!
:thumbup: This is all working now. I will get to check the speed when I get someone to unplug me.
C4/5 tetra
wheelchairer
Postby Burgerman » 27 Jan 2025, 14:23
It will go full speed.
On profile 3 use the SLOW speed. Indoors. It will just go slow and exactly follow the stick. Or it should. If it does then try speed 2 indoors.
Try the faster speeds only outdoors.
Postby wheelchairer » 29 Jan 2025, 13:43
All good thank you John
C4/5 tetra
wheelchairer
Users browsing this forum: Seafighter and 257 guests
