Quickie Q300m mini programming
Postby Gregrb » 14 Feb 2025, 17:48
I have rnet own dingle and program.the chair has non screen version of rnet joystick.wilk programmer work I hsv3 used in chairs with screen on rnet joystick work ok to program speeds
Gregrb
Re: Quickie Q300m mini programming
Postby Burgerman » 14 Feb 2025, 23:32
I read that several times. I still dont know what you are asking. :oops:
You have an r-net programmer? OEM or Dealer?
You have a chair with the LED joystick, will it program that? Yes.
The rest, no idea what it means?
Postby emilevirus » 15 Feb 2025, 00:12
You'll need to use usb port and a computer.
emilevirus
Postby Burgerman » 15 Feb 2025, 00:14
You know what he is asking? :fencing
Postby Gregrb » 15 Feb 2025, 16:58
Sorry if my question was not clear my disability effects my hands so typing is hard. I have OEM programmer . laptop with rnet software. I am asking will that work to program Q300m Mini that has a RNet LED Joystick ( not a LCD screen version which I've programmed in the past on other chairs). See link below of joystick. Will I be able to program the speeds on the chair still??
https://www.beyondmobility.co.uk/products/rnet-led
Gregrb
Postby Burgerman » 15 Feb 2025, 17:22
Yes. As normal. No differences in programming.
When you program a chair then you are actually programming inside the power module. And joysticks are interchangable. All work on all chairs.
Only joystick specific items such as remapping buttons on the fancy CJSM2 joystick will not work with LED joysticks. Because they dont have those buttons. Everything else is the same.
Postby Gregrb » 15 Feb 2025, 19:00
Thank you that's great. yes I know it's program in the rnet module.so the module is the same then. Is there a fashion of the programming software that is specific to that particular Wheelchair make and model? If so, do you know where I can download it from and any tip specific to that chair?
Gregrb
Postby Burgerman » 15 Feb 2025, 19:05
What chair?
What software do you have?
What version?
There are a few differences in power modules, different power levels etc, so you need to take that into account or not change thigs you dont understand... But different manufacturers may have some differences in what you will see listed in the menus. And matches custom firmwares etc. Mostly the same though.
Postby Gregrb » 15 Feb 2025, 22:46
Quickie Q300m mini
Software that came with the OEM dongle. Is there a place to download sunrise quickie software?
Only tweaking speeds
Gregrb
Postby Burgerman » 15 Feb 2025, 22:50
PM me...
Users browsing this forum: Burgerman, emilevirus and 471 guests
