BCrip71 wrote:Can I charge through my joystick?
shirley_hkg wrote:BCrip71 wrote:Can I charge through my joystick?
BCrip71 wrote:Can you fly with them?
Burgerman wrote:They have all the same issues that a typical 1 size fits all BMS has that isnt really needs. But at 130Ah thats enough to make to swap worthwhile.
With a couple of provisos...
129MM TALL is a bit taller than most grp 24s are. And that does not include the terminals or the bolts. So IF theres enough room.
And the usual one.
DISCHARGE SPECIFICATIONS
Continuous discharge current 100 A
With a few secs at 200.
Well a chair driven by my granny with stock programming would be fine at this level. And never pull more than say 60Amps.
But I know that I can make my 2x 120A R-net system pull 120A per channel, so more than double this occasionally with it programmed to go and steer and driven like I stole it. Not everyone does that...
So it wouldnt work for me, the BMS would keep on chopping off the power until it was reset. Will it work for you?
Only you can know how you use it! How its programmed? Maybe it will be fine.
I didnt see a price. But its only half the capacity of doing it with seperate cells at a 244Ah (measured) diy setup @ 560 us dollars?
So I would not expect it to be a realistic price! But I cant tell. Is it better than lead, yes. If it fits. If it doesent cause issues with BMS.
If it were me I would get a shirley ZTE ZXD POWER SUPPLY TO PROPERLY CHARGE IT and dont rely on some junk or a mobility charger.
So if you are going to do this make sure that they will actually fit! And that they will take them back if they start cutting out on ramps or big slopes or while accelerating at max power.
But I think they should be OK. You will get double the range, with 20 Ah remaining. Which you shouldnt use... Thats the just in case bit.
Users browsing this forum: jehan and 384 guests
