MotorCompensation: - reads only the motor current
Disabled
- Code: Select all
IF AccelBoost > 1 THEN
' GoSub TurnMix
' GoSub CompMix
END IF
' GoSub ThrottleCrossZero
youtu.be/SbWJPTNde34
' GoSub TurnMix
' GoSub CompMix
END IF
' GoSub ThrottleCrossZero'number of reads for smoothing internal current sensor readings
CurrentAveragingCycles = 1
' ILeft = GetValue (_A, 1)
' IRight = GetValue (_A, 2)
GoSub SmoothedInternalCurrents
SmoothedInternalCurrents:
DIM SumILeft AS Integer
DIM SumIRight AS Integer
SumILeft = 0
SumIRight = 0
FOR i = 1 AndWhile (CurrentAveragingCycles)
SumILeft = SumILeft + GetValue (_A, 1)
NEXT
SumIRight = SumIRight + GetValue (_A, 2)
NEXT
ILeft = SumILeft/CurrentAveragingCycles
IRight = SumIRight/CurrentAveragingCycles
RETURN 'SmoothedInternalCurrents
DIM ForeAftPower AS Integer
' ForeAftPower = (abs(GetValue(_MOTPWR,1)+GetValue(_MOTPWR,2)))/2
ForeAftPower = (abs(GetValue(_BSR,1)+GetValue(_BSR,2)))/2
DIM ExtraComp AS Integer
IF (abs(Steering)>1) AND (ForeAftPower<TurnBoostLimit) THEN
ExtraComp = 1
ELSE
ExtraComp = 0
END IF MotorCompensation:
DIM M1 AS Integer
DIM M2 AS Integer
DIM BattVolts AS Integer
DIM M1Comp AS Integer
DIM M2Comp AS Integer
DIM M1Speed AS Integer
DIM M2Speed AS Integer
SumILeft = 0
SumIRight = 0
M1Speed = GetValue (_BSR, 1) 'Min: -1000 Max: 1000
M2Speed = GetValue (_BSR, 2)
BattILeft = GetValue (_BATAMPS,1)
BattIRight = GetValue (_BATAMPS,2)
M1Power = GetValue (_MOTPWR, 1) ' фактический уровень ШИМ. Min: -1000 Max: 1000
M2Power = GetValue (_MOTPWR, 2) ' Syntax Scripting: = getvalue(_P, cc)
'get motor current values in accord with sensor setting
' ILeft = GetValue (_A, 1) 'estimated current in units of deciAMPS = 10X Amps for left motor (1 unit = 100 mA)
' IRight = GetValue (_A, 2) 'estimated current in units of deciAMPS = 10X Amps for right motor (1 unit = 100 mA)
NEXT
NEXT
' do mixing to find motor values (DO NOT TRUNCATE - will be un-mixing later)
M1 = Throttle + Steering
M2 = Throttle - Steering
'apply IR compensation; everything converted from volts to 0-1000 joystick units and *100/10 used to reduce granularity
M1Comp = 0
M2Comp = 0
BattVolts = GetValue (_V, 2)
ExtraComp = 1
ELSE
ExtraComp = 0
END IF
'Calculate mean back EMF as IR and motor compensation as percent (back EMF/BattVolts)
M1Comp = (ILeft*(MotorResistance+CompTurnBoost*ExtraComp))/BattVolts
M2Comp = (IRight*(MotorResistance+CompTurnBoost*ExtraComp))/BattVolts
'modify motor command values in accord with motor compensation
M1 = M1 + M1Comp
M2 = M2 + M2Comp
'undo mixing to get back new THROTTLE and STEER values
Throttle = (M1 + M2)/2
Steering = (M1 - M2)/2
'truncate in case compensation pushed THROTTLE and/or STEER over maximum of +/- 1000
IF (Throttle > 1000) THEN
Throttle = 1000
END IF
IF (Throttle < -1000) THEN
Throttle = -1000
END IF
IF (Steering > 1000) THEN
Steering = 1000
END IF
IF (Steering < -1000) THEN
Steering = -1000
END IF
PRINT (" M1Comp ", M1Comp , " M2Comp " , M2Comp ,"\n")
PRINT (" Speed = ", Speed, " Turn = " , Turn, "\n")
PRINT (" THROTTLE = ", Throttle, " STEERING = " , Steering, "\n")
PRINT (" ILeft ", ILeft , " IRight " , IRight ,"\n")
PRINT (" \n")
RETURN 'End of "MotorCompensation:"ScaleThrottle:
DIM PercentThrottle AS Integer
PercentThrottle = abs(Throttle*100)/1000 ' used in MixAccel
Throttle = (SpeedPot*Throttle)/100
' PRINT ("THROTTLE/STEER scaled Throttle = " , Throttle , " ")
Speed = Throttle
RETURN 'End of "ScaleThrottle:"
ScaleSteering:
DIM RelSpeed AS Integer
DIM TurnReduction AS Integer
Steering = (TurnPot*Steering)/100
IF (Throttle < 0) THEN
RelSpeed = (Throttle*100)/-1000
ELSE
RelSpeed = (Throttle*100)/1000
END IF
TurnReduction = (RelSpeed*(100-TurnAtFullSpeed))/100
Steering = ((100-TurnReduction)*Steering)/100
' PRINT ("THROTTLE/STEER scaled Steering = " , Steering , "\n")
Turn = Steering
RETURN 'End of "ScaleSteering:"SumILeft = 0
SumIRight = 0
NEXT
NEXT
IRight = SumIRight/CurrentAveragingCyclesIn my script, I removed everything unnecessary; it was simpler that way. SumILeft = 0
SumIRight = 0
but I don't see Speed end Turn anywhere in the piece of code in the message.Speed end Turn I take it here
This is a change that might cause problems! _MOTPWR and _BSR measure two different things. _MOTPWR is what the Roboteq calculates and sends (after further processing) to the motor. _BSR is the speed of the motor itself read from whatever sensors are being used. We KNOW that _MOTPWR works. _BSR might also work, or might even work better, but we don't know that. This is something that you should test later, not now.I changed it (ForeAftPower)
What do you think is not right here? Maybe my mind is too tired to see the problem, but I don't. This is a place where some print statements may help me understand what you mean, and to help us fix the problem if there is one. So this is a good point to talk about PRINT.Lenny, something's not right here.
SumILeft = 0
SumIRight = 0
NEXT
NEXT
PRINT ("\n SumI: ",i," ",SumILeft, " ",SumIRight,"\n")
PRINT ("\n AvgI: ",ILeft, " ",IRight,"\n")
RETURN 'SmoothedInternalCurrents 'Calculate mean back EMF as IR and motor compensation as percent (back EMF/BattVolts)
M2Comp = (IRight*(MotorResistance+CompTurnBoost*ExtraComp))/BattVolts 'Calculate mean back EMF as IR and motor compensation as percent (back EMF/BattVolts)
M1Comp = (ILeft*((MotorResistance+CompTurnBoost)*ExtraComp))/BattVolts
M2Comp = (IRight*((MotorResistance+CompTurnBoost)*ExtraComp))/BattVolts M1Comp = (ILeft*(MotorResistance+CompTurnBoost*ExtraComp))/BattVolts M1Comp = (ILeft*(MotorResistance+(CompTurnBoost)*ExtraComp))/BattVoltsM1Comp = ILeft*(MotorResistance)/BattVolts'Before tuning and just starting movement, MotorResistance = 50 CompTurnBoost =100% and ExtraComp = 0
impedance = (50+1*0) = 50 milliOhms
'and when chair is moving
impedance = (50+0*0) = 50 milliOhms 'starting movement -
impedance = (50+1*20) = 70 milliOhms'Before tuning and just starting movement with MotorResistance = 50, CompTurnBoost = 0 and ExtraComp = 0
impedance = (50+(1))*0 = 0 milliOhms
impedance = (50+(0))*0 = 0 milliOhms 'starting movement -
impedance = (50+(1))*1) = 51 milliOhms '-- impedance slightly boosted from 50 to 51
'when already moving -
impedance = (50+(0))*1) = 50 '-- boost of MotorCompensation disappears when already moving< correct behavior'starting movement -
impedance = (50+(1))*20) = 1020 milliOhms '-- RUNAWAY!
impedance = (50+(0))*20) = 1000 '-- RUNAWAY!motor compensation is assistance (amplification) for turning the chair in place and that the motor compensation program itself is correct, but its implementation is flawed. But in fact, motor compensation is always the addition of readings to the joystick, EVEN WHEN IT IS NOT NEEDED.
He is absolutely correct. The MotorCompensation: subroutine is called all the time, but the result of its calculations is not "always the addition of readings to the joystick". As you once said "it's only math", so here's a spreadsheet in which I've put some numbers and done the math to show the result of MotorCompensation: in a variety of situationsIt doesent.
It literally does nothing.
It responds in direct proportion to load.
I do not appreciate the ill-tempered, ill-informed, almost entirely incorrect diatribe in your last posting. At first I was tempted to correct what you've written sentence by sentence, but then I wondered whether I should just not respond at all. Finally, I have decided to respond only to your statements about MotortCompensation.
The nitrous oxide system on a drag car. Imagine it's always on and interacting directly with the gas pedal.
That's how the motor compensation works in your Roboteq controller.
You can see all this if you disconnect the motors from the gearbox.
I have great respect for the work you have done, but I don’t need help with my chair.
If, however, you have decided, as your last message implies, that I am an idiot who doesn't understand wheelchairs and doesn't know what he's doing, BYE BYE.
Users browsing this forum: duke1, LROBBINS, martin007, robertnew16 and 377 guests
