Drive wheel creaking every time I turn?
Postby Jay_x » 03 Oct 2025, 17:41
Every time I make a hard right turn my left drive wheel makes a weird creaking sound
stops once the turn is over.
what do you think?
Jay_x
Re: Drive wheel creaking every time I turn?
Postby Burgerman » 03 Oct 2025, 17:45
Well I would take it apart, grease the wheel bolts, the face where it sits against, then remove the hub, grease the axle and replace it. Ten check to be sure the tyre does not rub against anything. Reaasemble and test. If it still does it, then check all suspension axles, shock absorber mounts, etc.
If it still does it put it in a skip. Or get ear plugs.
Postby Jay_x » 03 Oct 2025, 18:03
I see, well with the nerve damage I have I can't really do all that. Its been like this for a couple weeks, not sure to take it into the shop or not.
Jay_x
Postby Burgerman » 03 Oct 2025, 22:10
Doesent sound very serious.
And look at it like this... If a motor/brake is actually failing then its already defective. And those things come as a combined replacement anyway. So drive it and see what happens. It might just go away. Or get worse. Either way nothing to lose!
My freinds big suzuki motorcycle had a tiny clutch rattle. I fixed it for him in one hour. I fitted a full drag race open exhaust. It made your ears bleed... He never heard it rattle again. Sometimes mechanical things do make a noise even if nothing is wrong. Or they blow up.
Postby Jay_x » 04 Oct 2025, 02:31
ok thanks
Jay_x
Postby Burgerman » 04 Oct 2025, 07:39
If it gets worse then it will be more obvious what is wrong. You could just check the obvious by getting someone handy like a teenager with a motorbike or a guy in a tyre fitting place on the street etc, to grab a wheel and rattle it back and forwards to see if theres any free play, check wheel nuts and look for the obvious just in case. Anything deeper would involve the sort of thing you cant do. And that would mean a bit of major surgery... At that point you may as well wait and see if it gets worse or goes away...
Me? I keep sets of spare motors on the shelf, and spare chairs sat around. Just in case. And if I hear a funny noise I take things apart to investigate. Not everyone can do that. Ebay is your freind. In advance. But if you cant investigate :hammer you also cant swap a motor... I cant either, but I can delegate! And have carers, nephews, etc.
If you dont have anyone to help, then do the following (as I also do just in case!)
I got a bit of paper through the door the other day. As I often do. Or a business card, flyer etc. Some I keep.
In this case, from a keen 16 year old. He wants to wash cars and says he likes cars! And a DIY printed "leaflet" shows him to be keen and @ £10 a car... Most young people are lazy and dont want to work. This one is different. I already like him! In your situation I might call and ask if he is interested in learning something new. And helping you for a few £££. But thats because I already have spares, and tools, etc.
I kept his scrap of paper (as well as 4 or 5 similar ones in the last year) in case I need someone useful to help me do cars, chairs, gardens, cleaning drives, DIY etc. Because you never know.
Think laterally!
Users browsing this forum: emilevirus, martin007 and 583 guests
