Legrest spring too hard
Postby faico_26 » 18 Oct 2025, 18:19
I have a problem with the legrests of my Q300R. The lever to open the footrests is very stiff because the spring is very hard. The problem is that there is no way to take the spring out to replace it for another one softer. I have weak hands and it’s a problem.
Any idea how could I soften the spring or how could I take it out from the legrest to replace it?
faico_26
Re: Legrest spring too hard
Postby martin007 » 18 Oct 2025, 20:07
Consult the parts manual...
Postby faico_26 » 18 Oct 2025, 20:15
Here the legrest.
faico_26
Postby faico_26 » 18 Oct 2025, 20:16
Another pic.
faico_26
Postby faico_26 » 18 Oct 2025, 20:17
martin007 wrote:Consult the parts manual...
I didn’t find anything helpful in the parts manual.
faico_26
Postby martin007 » 18 Oct 2025, 20:23
That piece looks like it is not removable or repairable.
Postby faico_26 » 18 Oct 2025, 20:32
martin007 wrote:That piece looks like it is not removable or repairable.
Exactly. So i don’t know how can i soften the spring.
faico_26
Postby Burgerman » 18 Oct 2025, 21:07
Centre foortest. Those make your chair too long. Here comes my legs. Here comes me. You are forced to sit over the front casters.
Postby Raro » 18 Oct 2025, 21:11
I can't tell you how to dismantle it, but that system is crap in my opinion. Some that work wonderfully with little effort and are much smaller are the ones that the old Quickie used, maybe you could adapt some.
Raro
Postby Raro » 18 Oct 2025, 21:17
Using a central one is a better solution if you can bend down to pick it up; if you depend on someone else to do it for you, there is no problem.
Raro
Postby faico_26 » 18 Oct 2025, 22:01
Raro wrote:Using a central one is a better solution if you can bend down to pick it up; if you depend on someone else to do it for you, there is no problem.
Exactly, I discard center footrest because I would not be able to raise it up or raise my legs to the footrest. The manual legrests allow me to do it by myself.
Regarding legrests I need that they are light, aluminium, not iron.
And I need to be able to open them. That’s my current problem, the hard spring.
I could try to cut a little bit the spring with the Dremmel but I’m not confident about the results.
faico_26
Postby Burgerman » 19 Oct 2025, 00:14
A shorter spring is not softer. Its just shorter. And takes more effort to compress by a similar amount. So now harder. Someone put it in there. So it must be possible to take it out too. Pics not good enough angles to be able to see how. Take everything apart! :hammer
Postby martin007 » 19 Oct 2025, 00:27
After fitting it they put in a plastic rivet...
Postby Burgerman » 19 Oct 2025, 00:49
Well if they put it in, your job is to take it out!
Postby faico_26 » 19 Oct 2025, 00:59
Burgerman wrote:Well if they put it in, your job is to take it out!
I will check it again.
faico_26
Postby faico_26 » 19 Oct 2025, 01:40
It’s like they put the spring and solder the plastic pieces. Impossible to open. I’ll keep looking for a solution.
faico_26
Postby Burgerman » 19 Oct 2025, 10:50
:hammer
One way or another that spring can be got out and replaced. You are giving up too easily. Dont be defeaed by a quick look. Dont be that person! :fencing
Postby faico_26 » 19 Oct 2025, 22:37
Fixed!!!!!
It had a metal hinge pin. I took it out and i could take the spring out. Luckily i could use the springs of an old Rc car.
Now it works like a charm.
faico_26
Postby faico_26 » 19 Oct 2025, 22:38
The pin
faico_26
Postby faico_26 » 19 Oct 2025, 22:40
All pieces
faico_26
Postby faico_26 » 19 Oct 2025, 22:41
The “donor”
faico_26
Postby faico_26 » 19 Oct 2025, 22:42
The new spring inside
faico_26
Postby martin007 » 19 Oct 2025, 22:43
Congratulations! :thumbup:
Postby Burgerman » 19 Oct 2025, 22:49
Told you...
:thumbup:
Whatever you do its never easy. If you dont accept defeat like most do, theres always a way!
Postby martin007 » 19 Oct 2025, 22:51
Burgerman wrote:Told you...
:thumbup:
"Everything has a solution, except death."
Postby faico_26 » 19 Oct 2025, 22:52
:thumbup:
Yes!!!!!!
faico_26
Postby faico_26 » 19 Oct 2025, 23:09
All we know the answer I would have received if I went to the shop to ask to soften the spring: “impossible”.
faico_26
Postby Burgerman » 20 Oct 2025, 00:15
Correct. Thats why I never do. Be it computers, cars, doctors, chairs, whatever. I decided long ago that the vast majority of supposed experts were useless. Goes double for politicians.
Postby faico_26 » 20 Oct 2025, 00:36
Burgerman wrote:Correct. Thats why I never do. Be it computers, cars, doctors, chairs, whatever. I decided long ago that the vast majority of supposed experts were useless. Goes double for politicians.
I agree.
faico_26
Postby ex-Gooserider » 21 Oct 2025, 01:39
Congratulations on a successful fix! cheers
FWIW, you beat me to it, as scrolling through the thread, I was mentally composing a message suggesting that you do exactly what you did other than having any suggestions about sourcing the replacement spring...
Users browsing this forum: No registered users and 377 guests
