Burgerman wrote:This will get complicaed fast.
I already replied to that other thread in depth just now...
1. A battery current can be 10% of the motor current. And as you speed up, the battery current can be 100% of the motor current. So BATTERY and MOTOR current are 2 completely seperate independant things.
2. Measuring battery or motor current wont tell you much unless you understand a lot more about how and what is actually happening!
And I will leave it there until you ask a few questions one at a time!![]()
To measure MOTOR current (battery current will tell you nothing useful here) you need to measure the current in ONE motor wire. So you must extend the wire from one motor brush, to the clamp meter on your knee and back again... Unless you do you cant measure anything!
With one SIMPLE exception. Buy R-Net as that can show you battery voltage, battery current, motor 1 volts, and current, motor 2 volts and current all in real time as you drive, speed up, slow down and stall the chair...
See here:
Burgerman wrote:Questions.
How heavy is your chair?
How heavy are you?
Is this mid or rear drive?
Because all my own chairs are 6mph (10kph) and NEED that 120A even with low impedance batteries, and GOOD correctly set up programming.
Why? Because unlike 6mph chairs from say 10 or 20 years ago they are now DOUBLE the weight. Most of my chairs are now 170 to 190KG up from the 80 to 90 in the past.
I too have added a few pounds over the years as many do as we get older.
So now those same 6mph motors that worked fine with an 80A controller in yesteryear need to move double the mass. That takes double the current. That would really require motors that were HALF the impedance (it didnt change) and controllers that can do double that 80A which also didnt happen. So the motors do not pull enough amps, and if they did then the controllers couldnt provide that power anyway. If they could then the BATTERY which has not grown also cant supply this current.
Can you see why batteries no longer last, chairs cant climb curbs. Controllers roll back power. Etc etc. Its a doom loop!
Burgerman wrote:When it reads low, what will that tell you?
Because it will.
How do I know? Because you have almost no torque. And torque is directly proportional to Amps.
We already know that. So what does that tell you?
Burgerman wrote:Note.
There are 2 different VR2s that have either identical connectors to R-Net, so plug and play. Or a diffferent one. I THINK sunrise use the common connectors one so that they can offer either R-Net or VR2 on a chair and its plug and play. Check.
Do your motor and battery connectors look like this R-net, if so plug and play:
Burgerman wrote:>>>- R-Net ISM-6L (ref. QML110032) (lighting, seat module) - 215€
£40 to 50 typically, I have 4 of these spare.
>>>- Joystick (screen colour) - 600€ or 800€
I only buy NEW joysticks.
Or brown box brand new "refurb" UNITS. (These are actually part ex units that come from PG Drives, and are indistinguishable from new as they are fully remanufactured.) They may contain some used parts internally. Externals are all new. Screens all new. Buttons etc all new. Its impossible to tell they are not new. Or maybe they are!
I paid £40, and £50 for basic LED joysticks.
I paid £80 for a CJSM as far as I can tell brand new.
I paid 125, 125, 150 for my 3 spare CJSM2 new joysticks.
>>>- R-Net 120AMP module - 520€
£40 to 45 typically eBay as new or clean used.
As you see I have 5 of them!
Including one that was £50 including a couple of bus cables, and the ISM-6L included too...
All this stuff DOES come up on eBay. Usually its for a matter of minutes and its gone. Or the price is almost right, so I make an offer. I lok for stupid descriptions. like "brain" or wheelchair joystick, or control module, etc Because they get relisted to sell cheap as nobody can find them. On german, US, UK, spanish, whatever eBay. It takes patience and perseverance. Dont buy used joysticks. Make silly offers...
martin007 wrote:Which powerchair do you have, faico_26?
How much do you weigh approximately?
Burgerman wrote:You will need to make an adapter. That allows you to plug in between a motor and the power module. One wire can go straight to the power module. About 6 inches long. The other one needs to go wherever your clamp meter is. A long loop. 10 sq mm cable.
It’s easier and quicker to just fit the R-Net and let it tell your laptop the batt voltage and current, and each motor voltage and current as you roll.
Raro wrote:Faico already has the programming cable and the software to use it, so why don't you send him a modified file like you did with JohnnyUK? It seems he was happy with the change.
Burgerman wrote:Q300 is a narrow ligher weight chair.
It uses small batteries (meaning they dont much like heavy loads because higher impedance) and generally are sold with quite low spec, so VR2 and 4mph and thats partly because price and partly because small batteries dont much like 4 pole/120A controllers/6mph... And yes with the seat lift etc its heavy!
I dont think 4 pole 6mph motors, are a good idea with small batteries and a heavy chair.
Burgerman wrote:Well I could do that and garantee pretty much know how it will respond. But thats R-Net. This is VR2 which I have no experience of. So while many settings might respond the same way I cant know this... So it would be a little risky!
Users browsing this forum: Bubbernator, Juggler258, Yennek and 343 guests
