Burgerman wrote:Why? I cant say I ever notice or care.
Most 4 pole motors are noisier han 2 pole. Because they have more "pulses" per revolution. And so more power or torque. On a 2 pole motor the poles happen every half a revolution, and they build gradually and then "release" gradually. With 4 poles then that happens more suddenly and twice as frequently.
I just added a CORRECTLY configured profile to magic V6 chair...
By PM.
Sent: Sun Jan 11, 2026 2:06 pm
by Seafighter
WOW! The steering is absolutely amazing!
I never understood the need for five different profiles.
it is so much better just to push the joystick to match the speed you want to make the chair go.
No more hovercraft mode!!!
faico_26 wrote:Hi BM,
I see that you have a Q700R (nice with those tyres). And watching the pictures of your chair i can see they are 4 pole motors. I guess these are the same motors I have in my q300r. As you may remember, my motors make a humming sound which is due to the 4 poles. But worse is that my motors stall with just 3cms curbs. I have 90amp VR2. And i see that you have R-Net, is it 120amp? Can you climb curbs or it also stalls?
Burgerman wrote:>>>My chair gets 9km/h not more. I have 12,5” rear tyres. I tried another q300r with 14” tyres and the same motors and the speed was the same.
Not logical. How are you determining speed?
Also that rpm figure is quite useless. It tells you only rpm per volt in a free running unloaded motor. Real speed depends on load, voltage, etc which is determined by motor impedance, battery or wiring impedance, rolling resistance, so tyre dia=meter and even pressures, your and the chair weight, CG position, how level the surface is, temperature of motors, batteries and battery type as well as programming.
For e.g a lower impedance motor may have lower free running rpm, but will respond better to compensation, and will slow less under rolling loads. But may/need a lower impedance battery to do so. Or that battery voltage falls more under a load.
Lets say for the sake of understanding this you fitted a motor that was much smaller like one from a hairdryer or a toy. It turns much faster, say 25,000 rpms. And is much higher impedance. So draws much less current. Will the chair go faster? No because it doesent draw enough current to make enough torque (its impedance is way too high) so the chair likely will be super slow or wont even move. If you lift the wheel off the ground then it will spin very fast!
Burgerman wrote:Do you mean noisy because of a fault or noisy just because they are wereworking and making a normal sound?
Users browsing this forum: LROBBINS and 245 guests
