#1 She is blind in the left eye from a stroke and color blind in the right eye with cataracts. While a surgeon could address the cataract, she doesn't want to risk it and I understand. However she can't see the power button and has trouble with reading the display. I tried putting a cabinet bumper on the power button for tactile identification but it won't stay stuck. Any advice on something that worked for you? This is the biggest issue since she gets into the chair from bed then is stuck trying to understand why it won't move.
#2 I don't like the way the chair turns (too fast even at lowest speed). I have a CAN adapter arriving next week with hopes of adjusting drive parameters. I have all the necessary software in place, so I assume I just follow the directions in the sticky's. This should arrive in about four days, my plan is to eventually connect it using a 6pin molex connector using a can multiplier, but for now loose fitting pins in the armrest is the path. Would anyone recommend against changing the acceleration's based upon her age and mild dementia.
#3 I'm concerned about her pinching her hand in doorways, so I have ordered a swing-away mount (left and right) and necessary hardware for this chair. These parts should arrive in four or five days. For now I'm watching her like a hawk when I hear the joists in the house squeak (indicating a heavy chair is on the move). I'm hoping if her hand gets pinched, it will force the controller to the left and avoid her getting hurt. Is this adequate or too big of a risk (alternative is assisted living)?
#4 I've bought an attendant joystick and mounted it rearward so I can access it if she gets stuck with the main control inaccessible or if I choose to take control away from her. I did a quick test to make sure it's functional by using the connector for the main joystick (main joystick was unplugged). It worked but had flashing lights which I hope to diagnose once the CAN adapter comes in. Long term I will use a multiplier to ensure all peripherals are always connected to the CAN bus. Any Advice on problems I might run into with attendant controls?
biscuit wrote:This is what i use for tactile guides:
https://amzn.eu/d/05MQMHGi
They are little plastic rhinestones assorted shapes, cost a fiver or so for half a dozen sheets. I use them everywhere espcially on wheelchair on off switches. My one eye is mostly blind.
I have a wheelchair in my very unadapted house, i went for the shortest wheelbase I could find which seemed to be the Roma Vienna. The width was less problem in tight spaces than the length.
Burgerman wrote:This all sounds like it will end with more care, someone else in charge.
cpetku wrote:Mom managed to push the mode buttons and set the drive profile to #3 (I intend for her to only use #1 in house). She pinned her leg between the chair and wall apparently while turning and couldn't figure out how to solve this since she was in a lot of pain and will probably have a bad bruise. All I can think of is to program her four drive settings to low speed values so if she pushes the mode button it will have no effect. I really need to slow the turn rate down as even with a limit switch activated to run the chair at half of the lowest speed, turning is just too fast. I should be able to set the attendant control to a higher speed for my use in moving the chair around the house but the Curtis documentation implies I only get one drive profile setting for the attendant control. Maybe a newer Q-Logic control with a knob for speed control is an option. The CAN adapter is in Arlington IL waiting on the last mile delivery service to bring it over to Michigan. Maybe I'll have it on Wednesday and can avoid this happening again. If I can't solve this then the chair will get retired before it had much of a chance to help her. I can't risk her being pinned for an extended period while I'm working outside in the yard or at the office.
Users browsing this forum: DennisinTexas, duke1, emilevirus, Superchunk and 377 guests
