I was stalled the other day and max I saw being pulled from the battery was ~130A. Same thing when I had my Magic Extreme X8. It peaked at around 130A stalled and that's 4x motors ~30mohms resistance
I understand that but I mean.
I always struggle to get over my doorstep. It stalls even my 10kph chair then pulls 130A from battery.
If I hold my joytick it holds steady at 130A. Does the controller limit me or the motor resistance does?
emilevirus wrote:Generic version won't allow past 25v, Sunrise does.
Burgerman wrote:I have here 2 versions that are R-Net GENERIC version 7.0.xxx from two sources inc PG Drives that are both supposed to be the latest.
One is compiled to work with the newer PM2 and has all sorts of battery config options and all sorts of internet connections and spying uploading motor and battery usage parameters and that keeps massive logs...
On the face of it they look the same.
On the options on the left there are a few differences lower down and in the menus.
Take a careful look!
They dont install over the top of each other - both work at at once and are both GENERIC V7.0 in the start menu.
Users browsing this forum: acid_coke, Bing [Bot], Burgerman, emilevirus, jefferso, Mr.Math and 450 guests
