Burgerman wrote:Good. Watch the motor current on the tiny wires!
What value did you set motor compensation to?
How did you determine that it is corect?
Quite literally everything depends completely on that being right. It is too non responsive under load (under different loads) to have any considtency of control if its set too low.
It is snatchy, may damage motors, and may even run away with no way to stop it either spinning in place or driving forwards or backwards or some combination, or occilating etc if set too high. And the correct setting is quite critical.
Burgerman wrote:Well in the past, when swapping motors etc I just tested by feel.
I started with a value that was so low that it did completely nothing. Why? Because in order to "feel" it work you need to know how a chair responds without any when programmed in a normally responsive way. Try it turns in place, accelerating, decelerating, moving over a threshold, on a ramp. You will soon see why its super important! Even slowing down is drasically affected. Its ESSENTIAL to do this to gain a feel for things first
Then increase value in small steps and each step will appear to make no difference. Its only when you get close to the correct value that it suddenly begins to work. At this point a small change hs a big effect! Dont do large steps as if you go too far then you can have big issues...
At least in your case you know you can safely go to what you have set now.
Once you begin to feel it doing something and the chair feels much more responsive then keep increasing it and it will keep getting better. It will behave in a more controlled way regardless of load. The correct point is where for e.g it turns in place exactly the same "feel" on a thick carpet or a smooth tiled floor. Where at a FIXED low throttle (stick) position or set to speed 1 it doesent slow, OR SPEED UP as you meet a ramp regardless of angle. And where the response feels smooth still.
Go too far and it will get snatchy, uncomfortable. Go even further and it becomes almost impossible to control properly and very eratic. Go further still and you may get a runaway and broken legs. Or under a bus.
So thats what I do to get it correct.
Burgerman wrote:If its smooth its safe.
COMPENSATION
This matches the Power Module to the motors used on the wheelchair. This is necessary to achieve optimal performance and control, especially on a gradient.
The programmable range is 0mOhms to 500mOhms in steps of 5mOhms.
First of all, check that the wheelchair is controllable and comfortable to drive on a smooth, level surface. If it is not, then the value of Compensation may be too high and should be reduced.
1. Then drive the wheelchair towards a gradient at a very low FIXED speed, perhaps 10%. There should be no reduction in speed as the wheelchair climbs the gradient. If the speed drops or the wheelchair stops, then the value of Compensation may be too low and should be increased.
2. As a final check, drive the wheelchair up a gradient at full speed and release the joystick. The wheelchair should come to a smooth, complete stop and should not rollback before the brakes are applied. If the wheelchair does roll-back, then try increasing the value of Compensation slightly. If the wheelchair appears to drive slightly up the gradient before the brakes are applied, then the value of Compensation should be reduced slightly.
All these tests should be conducted when the motors are cold and hot.
WARNING:
These tests should be conducted in an open space and a restraining device such as a set belt should always be used. PGDT accepts no liability for losses of any kind arising from failure to comply with this condition.
The wheelchair manufacturer is responsible for ensuring that the value of Compensation is correctly set for the motors being used on the wheelchair. This is particularly important if replacement motors are being sent out to upgrade a wheelchair already in the field. Failure to comply with this requirement may result in poor control characteristics, which in extreme instances can make a wheelchair uncontrollable and potentially unsafe. PGDT accepts no liability for losses of any kind arising from failure to comply with this condition.
The wheelchair manufacturer is responsible for always ensuring that any replacement motors supplied as spare parts are fully compatible with the originals that the system was programmed to match. Failure to comply with this requirement may result in poor control characteristics, which in extreme instances can make a wheelchair uncontrollable and potentially unsafe. PGDT accepts no liability for losses of any kind arising from failure to comply with this condition.
A control system must not be moved from one wheelchair type to another without first ensuring that the system is correctly programmed for the wheelchair it is intended to fit it to. Even if control systems have the same PGDT part number, they may not be programmed the same. Failure to ensure the system is correctly programmed for the wheelchair may result in a hazardous condition. PGDT accepts no liability for losses of any kind arising from failure to comply with this condition.
Users browsing this forum: fordragon88, LROBBINS, shirley_hkg and 204 guests
