Wont bother me, as I would pull the link fast.
But maybe best is it cant do that if you are going to sell them to other people.
9.1.2.7 Sleep 12V
Depressing the Select button while this option is highlighted configures the Omni+
Module as to whether the 12V supply on the 9-way D-type connector is present when
the module is “asleep”. The settings are On and Off.
On Means the 12V supply will always be present. This should be set
if the input device requires a 12V supply to “wake up” the
Omni+ Module.
Off Means the 12V supply will be removed when the Omni+ Module
is “asleep”. This can be set to reduce control system power
consumption.
Burgerman wrote:I use the gear switch or throttle hold switch for this. And a different channel.
This memory loss causes no other problems than causing the Arduino to cease functioning?
APPLIED VOLTAGES
The JC2000 is designed to operate from a regulated 5Vdc ±0.5V supply, free from voltage transients. Under no
circumstances should voltages above 5.5V be applied to the joystick. The outputs from the JC2000 are ratiometric and are
dependent on the input voltage.
The analogue inputs are compatible with PGDT JC200BR3K1Y
It wasn't really my intention to have people driving themselves around by remote control ... rather it was to allow them to fetch or send the chair to somewhere ... then once seated.. turn off the R/C and Omni and use the joystick on the pod.
On the packaging - would it be possible to shoehorn the board into the joystick pod, which would mean that all you have coming out would be the wiring for the antenna?
Packaged for collection tomorrow ..probable delivery Monday.
Current Status: Hub Trailer Via Sorter
Ship Date: Sat 01/03/2014
Service: Hermes / Domestic
Your Parcel should be delivered no later than: Fri 07/03/2014
Parcel delivery within 3-5 working days throughout most of UK's mainland
Users browsing this forum: LROBBINS, martin007 and 393 guests
