The battery box is the standard sunrise part with a groove descending down middle to only give about 178mm maximum height at the front.
Thats not standard.
Normally a set of gel mk grp24 73ah batteries fits fine the right way up...
So If I'm going flat out up a hill expect 160A.. Wow 256 Watt with a R01 resistor, and loose a volt over it.
0.25V off the charging voltages will make a massive difference?
What sort of frequency does the power module throw it's pulses out at? (Too lazy to connect a scope up today)
Users browsing this forum: Bing [Bot], jehan, LROBBINS, saker98 and 445 guests
