My PL8 does not work(it died!)
Is there a working alternative balance charger I can use with Shirley's new ZXD2400 TFT 3.2" charger or another way of charging them.
Thanking all in advance
James
shirley_hkg wrote:https://www.wheelchairdriver.com/board/viewtopic.php?f=2&t=12583&p=210956#p210956
JK active balance (0.4A--2A) BMS, programmable and BT connectivity.
I can find decent PL8 (used).
emilevirus wrote:Or Junsi iCharger works fine too.
ZXD2400 plus a programmable BMS are pretty good, or Victron charger in power supply mode will also do.
Less than £30.
We all have 220Ah packs here. I seldom use PL8 now.
Less than £30.
Burgerman wrote:Any that can do 8S or greater. The more power the better as you are charging a large battery.
) and you charged it with that charger at say 25A. Then it would take about 10 hours. Chances are that it will be about 2/3rds discharged, so about 6 or 7 hours. Plus balance time. Again that shouldnt take long after initial build and balance.emilevirus wrote:
That's what I use. Works fine. Just don't charge at max. Charge at 25A. Leave some headroom.
Burgerman wrote:Yes. Use 12awg silicone for the charge wires.
Burgerman wrote:Something like this, 2A balance, BT 8S etc.
https://www.aliexpress.com/item/1005007 ... in_prod%3A
but what is the controller?
Dan wrote:Burgerman wrote:Something like this, 2A balance, BT 8S etc.
In the wiring diagram for that BMS the charger is the power supply but what is the controller?
Users browsing this forum: Bubbernator, jefferso, martin007 and 500 guests
