emilevirus wrote:So I got the 13x4 wheels but what if I want a set of 13x5 wheels. Is it a special hub or can I get a 13x5 rim + tire on Amazon?
Burgerman wrote:Its not. Its likely because they pay less for dynamic if they buy enough or something.
Both perform exactly the same. They will never be able to give a rational engineering reason. At least one that makes any sense. Try them.
They will say something like they have auto adaptive compensation adjustment or something. Its all nonsense.
so bounder wont sell you a high speed chair with R-Net controls on it because the braking algorithm isnt adjustable on it at all..
when ya let go if the joystick on an R-Net chair, a timer starts - when it runs out the brakes WILL TURN ON regardless of your speed or movement!
Dynamic LiNX however is adjustable and works MUCH better. if you are maneuvering slowly the brakes turn on almost instantly which is great!
you'll notice brakes are way more responsive with LiNX controls.
Once this value has been programmed, some drive testing should be carried out.
First of all, check that the wheelchair is controllable and comfortable to drive on a smooth, level surface. If it is not, then the value of Compensation may be too high and should be reduced.
Then drive the wheelchair towards a gradient at a very low speed, perhaps 10%. There should be no reduction in speed as the wheelchair climbs the gradient. If the speed drops or the wheelchair stops, then the value of Compensation may be too low and should be increased.
As a final check, drive the wheelchair up a gradient at full speed and release the joystick. The wheelchair should come to a smooth, complete stop and should not rollback before the brakes are applied. If the wheelchair does roll-back, then try increasing the value of Compensation slightly. If the wheelchair appears to drive slightly up the gradient before the brakes are applied, then the value of Compensation should be reduced slightly.
All these tests should be conducted when the motors are cold and hot.
R-net help:
This sets the deceleration rate that is used while the wheelchair is “soft-stopping”. “Soft-stopping” is if the system is powered-down while the wheelchair is being driven.
The programmable range is 0 to 200 in steps of 1.
If this value is the same or lower than the Forward Deceleration value, then the latter value will be used for “soft-stopping”.
WARNING:
It is the wheelchair manufacturer’s responsibility to ensure that the wheelchair complies with the correct legislation for braking distances for the country in which the wheelchair is to be sold. PGDT accept no liability for losses of any kind resulting from incorrect programming of this parameter.
Makes no sense to have all that protection nonsense on a chair anyway.
When this setting is turned on, the controller uses plug braking or internal dynamic braking, dissipating the energy as heat in the motor windings and FETs, not regenerating it.
>>>But in my case, it's just 10ah lithium so it hits LVC pretty soon.
Users browsing this forum: Burgerman, emilevirus and 462 guests
